Już jest link na steamie:
http://store.steampowered.com/app/619680/Assetto_Corsa__Ready_To_Race_Pack/Cytat od Marco na pytanie co z ceną: "7,99 €/$"
Newsy i foty o Lotusie.
- 900kg co daje stosunek mocy do masy ponad 500 km na tonę i jest w stanie przyspieszyc od 0 - 60 km/h w mniej niż 3.0 sekund przed osiągnięciem maksymalnej prędkości 290 km/h.
1.14 changelog:
- New autosaved replay options and UI added to launcher main theme
- Handicap (ballast & restrictor) options in custom championship mode
- New Audi TT Cup
- New Audi TT RS (VLN)
- New Audi R8 GT3 2016
- New Audi R18 LMP1 2014
- New Lotus 3-Eleven (race)
- New McLaren 570S
- New McLaren P1 GTR
- New Maserati MC12 GT1
- New Toyota Celica ST185 Group A
- Mandatory pitstop window is now related to pit entry timing (replacing old system)
- Pitstop animation enabled with oculus or STAY_IN_CAR enabled (system/cfg/pitstop.ini)
- Added Position set digital script
- Added ballast and restrictor option offline for championships and multiplayer. Work in Progress for offline quick race and race weekend UI
- Added wind algorithm
- If controller is keyboard then Pitstop app is replaced by mouse pitstop
- Mouse pitstop with Mouse Steering enabled is now working correctly
- Tweaked backfire flash flames in many cars
- Realtime app: qualify/practice colors are based on leaderboard position, race color on current position
- Added DIGITAL_PANEL script to display current position and P2P on car's external panels (Audi TT Cup)
- Added FUEL_PERC script to show fuel quantity as percentage (McLaren 570S)
- Fixed broken UI interaction due to session switching when pitstop was not finished
- Fixed rare automatic pitstop activation at car spawning in the pit
- Fixed deadzone for gamepads
- Fixed Tyre App thermal value for exploded tyres
- Minimum for automatic reset tyre on track is now 2
- Fixed flag rendering in VR with PP off (again, hopefully for real this time)
- Fixed Achievements from unlocking when car is blackflagged
- Pitstop app: new tyre pressure can only differ from the current one by 4psi (because of minimal height rule)
- Added Push To Pass system (Audi TT Cup), P2P amount depends on grid position, enabled in Practice and Race sessions only
- Added physics option for different fuel weight/density
- Adjusted Lotus 98T tyre wear
- Fixed old pitstop UI from allowing more fuel when setup is fixed
- Added Black Flag description
- Added Online time of day multiplier (x1 to x10)
- Added track animated starting lights
- Added blink feature to RPM SERIES script (updated all relevant cars)
- Added acServerManager 1.14.0
- Added Time multiplier
- Added Wind
- Added Restrictor (BoP)
- Fixed BoP server message to client
- Fixed bug on client fixed setup 2nd reloading
- Added resolution string on splash screen
- Added "safe mode" initialization when first DX11 init fails, it will try again with desktop resolution and AA/Fullscreen off
- Added AI Aggression selection
- More AI differences within a single lap to generate more battles
- Added AI wing setup variations
- Added new Random camera mode algorithm
- Fixed driver model visibility bug in Random camera mode
- Removed AI slowdown hack for cars with spool differentials
- Improved Downshift Protection algorithm
- Fixed AI giving away green light by flooring gas 500ms in advance
- New AI algorithms for understeer detection and downshifting
- Fixed Car Engineering app sometimes reporting wrong total and sprung weights
- Added Fuel x Time on Setup Fuel tab and pitapp (optional section in car.ini [FUEL_EXT] KG_PER_LITER=value)
- Added best splits at the end of the race on leaderboard timetable
- Tweaked leaderboard to show player name/position even if that player has disconnected
- Updated Steam statistic reader to synchronize steam achievement
- Added "virtual desktops" functionality to in-game GUI (cyclable through ctrl+u key combination)
- Fixed session synchronization issue when session switches while a new player is joining
- AI is now using kers
- Fixed Nissan Skyline R34 having downshift protection when it should not
- Added "variation" slider for AI. It will randomize the AI level in the range selected.
- Fixed Nissan GT3 texture map on lod B
- Added player's nation flag support (not valid flag will be rendered as AC logo)
- Added new Driver Label GUI (customizable in \system\cfg\name_displayer.ini)
- Added nation flags on leaderboard GUI
- Tweaked opponents list to include nationality
- Update special events to include nationality
- Added Mandatory Pit warning message at the start of the race
- Added minisectors to overlay leaderboard and performance delta app, this can be disabled through [Documents]/Assetto Corsa/cfg/gameplay.ini
- Some template updates to existing content
- Porsche 911 RSR 2017 template added
- Templates added for Lotus 3-Eleven, Audi TT Cup, Audi TT VLN, McLaren 570S, Mclaren P1 GTR, Toyota Celica ST185, Maserati MC12 GT1
- Minor graphical updates on the Porsche 911 GT3 Cup and Lotus Exige V6 Cup
- Digital display script tweaks across the board
- Fixed a bug on Nissan GTR GT3 LOD B
- Minor livery fix on Glickenhoue SGC003
- Python new functions:
getWindSpeed
getWindDirection
getDriverNationCode(CAR_ID)
getCarSkin(CAR_ID)
