Odpowiedz Posty: 5 Strona 1 z 1
Unofficial Patch by ermo
  • Izek
    autor: Izek » 19 lis 2013, 18:41
    Nie tylko nasze TDU posiada takich zapaleńców jak Xarlith i spółka. Z miłości do gry można jednak wszystko - szacun. Poniżej zamieszczam listę zmian w najnowszej wersji (1.1 oznaczona jako w 1.0.99f) oraz linki do instrukcji i pobrania. Enjoy! :angel:
    Lista zmian:
    Bug fix summary:
    Fixed reversed suspension link positions in aarm_multilink.sdf
    Fixed reversed toe values bug (flipped positive and negative values so that they now correctly match the tuning menu)
    Fixed sounds for Nissan 2000GTR and Nissan 240ZG engine swap
    Fixed Mazda RX8 and Porsche 914 engine descriptions
    Fixed bug in Bugatti Veyron rear-left "SlowBump" range
    Corrected power of Mazda RX7 FC rotary (stock and turbo upgrades)
    Fixed uneven ReboundTravel on many cars
    Fixed diffuser base value typos on various cars
    Fixed uneven left/right tuning on various cars
    Fixed front & rear wing range for Audi R8 LMS
    Fixed camber values on various cars
    Corrected fuel tank locations (some were up to 2m behind car)
    Fixed missing DiffPumpSetting values (from "DiffPumpSetting= " to "DiffPumpSetting=0" which was found to produce more consistent AI behaviour in Overhaul mod for Shift 1)
    Fixed a bug that prevented proper upgrade of Mercedes 190e Evo2
    Reduced the magnetized effect of collisions with walls/rails and other vehicles
    Fixed reversed mirrors in several cars
    Fixed syntax errors in tracks.lod files
    Fixed tuning level issue introduced by unpacking
    Fixed Nissan GT-R Engine-Swap 'Phantom Turbo' problem
    Fixed brake heating issue on Mazda RX-7 FC Speedhunters
    Fixed Lamborghini Murcielago vents so that they pop up at the correct temperature
    Fixed wheel offsets and sizes on a range of cars (wheelfixit v2.1)
    Enhancements summary:
    Revised installation method with a selection of unpacked game files for ease of modding and explicit compatibility with the Career Mod and the unpacked version of the Polish Tyre Mod for S2U.
    Support for dropping custom liveries (*.dds files) directly into the \vehicles\textures\ folder
    Includes optional unpacked UCP-compatible repacks of requested mods:
    XBox 360 Controller buttons by Kaerar
    DFGT & PS3 Controller buttons by vincentgarcia
    Unlock Hidden Car mods by Jeroen vd Helm
    Minimod dinput8.dll by Juls
    Removed intro movies for a faster game startup
    Enabled ability to skip career movies
    Increase garage spaces to 800
    Speedhunters DLC cars can now be sold back to car lot (for $0)
    Disabled reverse driving penalty to double available tracks in hot lap mode
    Increase maximum career level to 40 (1 million XP): Unlocks the arrow vinyls at lvl 35 and speedhunter vinyls at lvl 40. (reputation_level.xml)
    Change how reward cars are handled; all cars except rival cars are now available for purchase in the car lot, the rationale being that rival cars are unique (unlockableitems.xml, reputation_unlockables.xml):
    Nissan Silvia
    Alfa Romeo Giulietta
    Pagani Roadster HP
    Lamborghini Reventon HP Cop Edition
    Alfa Romeo 8c Spider
    Aston Martin DBS Volante
    Audi R8 Spyder
    Koenigsegg Agera
    Pagani Cinque Roadster
    Chevy Camaro Dr. Pepper
    Porsche Autobild GT3
    Created standard adjustment units for the following tuning options (set all base values to 0 while keeping original preset values, this way you know what you're actually setting for these items):
    Tyre pressure now displays the actual kPa value (previously we saw only a condensed kPa range, which varied between different cars, making tuning confusing)
    Steering lock now displays your actual steering lock in degrees (allowing easier comparison between cars)
    Differential Power/Coast/Preload
    Established a common base camber tuning range (-5 to +5 degrees) and adjustment value (0.1)
    Increased caster range from 0-7.3 to 0-10 degrees (higher values provide better ffb and more direct handling)
    Unlocked more default tuning options for lower tier cars
    Tweaked tyre sounds to be more prominent
    Tweak upgrade gear ratios for some cars (Moorsman74) and tweak stock gear ratios for others (transfixit v1).
    Tweak speedometer movement for cars with non-fixed speed 'ticks' (speedofixit v2)
    FAQ: KLIK
    UCP - co gdzie i jak:
    1) Strona główna - KLIK
    2) Instalacja - KLIK
    3) Pobierz (najnowsza najwyżej) - KLIK
    :ok:
    Ostatnio zmieniony 19 lis 2013, 18:41 przez Izek, łącznie zmieniany 2 razy.
    Siemkins
    Reputacja: 53
    Imię: Jacek
    Hobby: detailing, domowe wino, muzyka
    Samochód: Honda Accord VI
    Więcbork 2016 Szczyrk 2015 Bieliszów 2014 TorMania Regular Races Grozokonkurs
    Grozokonkurs Endurance
    Polubił: 1538
    Otrzymanych polubień: 1770
    autor: Siemkins » 19 lis 2013, 20:13
    I o to chodzi !! To jest magia gier, którą trudni wytłumaczyć nie-graczom.
    Prawdopodobnie najlepszy Admin na tym portalu z nickiem na "eS"
    Mogłem być majtkiem na twojej łajbie, a jestem kapitanem na swojej tratwie
    CZYTAJ TO
    Reputacja: 38
    Samochód: Omega B FL 3.2 V6, Caro+
    uPlay: Nie pamiętam
    Steam ID: gruszmen89
    Klub: Forever - Green Lights Comapny
    Polubił: 2640
    Otrzymanych polubień: 2319
    autor: Gruszmen » 25 gru 2013, 15:11
    Wypakowałem grę, wgrałem tego patcha na auta (Agera, Alfa Gullietta i Cinq) ale strasznie mi grę zacina w menu. U was też tak jest?
  • Izek
    autor: Izek » 25 gru 2013, 18:08
    Nie, wszystko działa "po staremu" :think:
    Reputacja: 38
    uPlay: Nie pamiętam
    Polubił: 2640
    autor: Gruszmen » 25 gru 2013, 18:10
    Czyżbym coś pokręcił :think: Tak czy inaczej auta lepiej się prowadzi.
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 9 gości
